[mapguide-users] adding a points layer from ODBC problem
Zac Spitzer zac.spitzer at gmail.com
Mon Dec 19 18:43:49 EST 2011
Hi there,
need more information, what kind of database are you using?
can you post your feature source xml?
z
On Mon, Dec 19, 2011 at 7:22 PM, nazeitgeist <nazeitgeist at gmail.com> wrote:
> Hi guys, I want to display the coordinate point from database and it can
> be done by adding a points layer from an ODBC data source. The problem is,
> when i preview the data, errors occurred "An exception occurred in FDO
> component. Internal error" i attach some print screen.. I'm using MapGuide
> OS 2.2, Maestro 3.5
> View this message in context: adding a points layer from ODBC problem<http://osgeo-org.1803224.n2.nabble.com/adding-a-points-layer-from-ODBC-problem-tp7107449p7107449.html>
> Sent from the MapGuide Users mailing list archive<http://osgeo-org.1803224.n2.nabble.com/MapGuide-Users-f1803227.html>at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20111220/5225bb9f/attachment.html
