[mapguide-users] Re: adding a points layer from ODBC problem
nazeitgeist nazeitgeist at gmail.com
Mon Dec 19 20:09:33 EST 2011
i'm using microsoft access database...
<?xml version="1.0" encoding="utf-8"?>
<FeatureSource xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
  <Provider>OSGeo.ODBC</Provider>
  <Parameter>
    <Name>DataSourceName</Name>
    <Value>penchala-other</Value>
  </Parameter>
  <SupplementalSpatialContextInfo>
    <Name>Default</Name>
<CoordinateSystem>PROJCS["WGS84.PseudoMercator",GEOGCS["LL84",DATUM["WGS84",SPHEROID["WGS84",6378137.000,298.25722293]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Popular
Visualisation Pseudo
Mercator"],PARAMETER["false_easting",0.000],PARAMETER["false_northing",0.000],PARAMETER["central_meridian",0.00000000000000],UNIT["Meter",1.00000000000000]]</CoordinateSystem>
  </SupplementalSpatialContextInfo>
  <ConfigurationDocument>config.xml</ConfigurationDocument>
</FeatureSource>
View this message in context: http://osgeo-org.1803224.n2.nabble.com/adding-a-points-layer-from-ODBC-problem-tp7107449p7110420.html
