[mapguide-users] BUFFER ERROR
Olcay Ebcin (Coğrafi Bilgi Sistemleri Şube Müdürü) OEBCIN at iski.gov.tr
Wed Dec 21 17:44:31 EST 2011
When I try to create a buffer on a point layer via fusion, I get the following error message.
Buffer Error
The coordinate system conversion failed. A point, a portion of a line segment or a portion of the region, is outside of the mathematical domain of the coordinate system.
The problem exists when Point layer has SRID of 23035 and Map is WGS84.pseudoMercator.
if Point  has SRID of 4326  and Map is WGS84.pseudoMercator Buffer Created Successfuly.
Any help is appreciated.
Regards,
Olcay Ebcin
