[mapguide-users] BUFFER ERROR
Zac Spitzer
zac.spitzer at gmail.com
Wed Dec 21 18:58:11 EST 2011
which viewer? which version of mapguide?
2011/12/22 Olcay Ebcin (Coğrafi Bilgi Sistemleri Şube Müdürü)
<OEBCIN at iski.gov.tr>:
> Hi,
> When I try to create a buffer on a point layer via fusion, I get the following error message.
> Buffer Error
> The coordinate system conversion failed. A point, a portion of a line segment or a portion of the region, is outside of the mathematical domain of the coordinate system.
> The problem exists when Point layer has SRID of 23035 and Map is WGS84.pseudoMercator.
> if Point has SRID of 4326 and Map is WGS84.pseudoMercator Buffer Created Successfuly.
> Any help is appreciated.
> Regards,
> Olcay Ebcin
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
