SV: [mapguide-users] Re: adding a points layer from ODBC problem
Von Barth, Peter
Peter.vonBarth at eon.se
Thu Dec 22 06:50:37 EST 2011
Hi!
I Have the same problem. And I'm sorry to say that the only way I could fix it was to roll back to MGOS 2.1 in this version it works.
Here´s a link to my thread http://osgeo-org.1803224.n2.nabble.com/ODBC-Connection-tp6355171p6357829.html
If anyone has a solution to this using 2.2 I would be very interested in reading the solution
//Peter
Från: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] För nazeitgeist
Skickat: den 21 december 2011 07:26
Till: mapguide-users at lists.osgeo.org
Ämne: [mapguide-users] Re: adding a points layer from ODBC problem
i already try to preview the feature data using 32bit and 64bit PC but same problem occurred.. An exception occurred in FDO component. Internal error even when i try it on maestro 4..same problem... does anyone have the same problem and knows how to solve this problem.. ? help me plz.. i'm a newbie..
View this message in context: Re: adding a points layer from ODBC problem<http://osgeo-org.1803224.n2.nabble.com/adding-a-points-layer-from-ODBC-problem-tp7107449p7114259.html>
Sent from the MapGuide Users mailing list archive<http://osgeo-org.1803224.n2.nabble.com/MapGuide-Users-f1803227.html> at Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20111222/64a9c83c/attachment.html
