[mapguide-users] Oracle Connection
Zac Spitzer zac.spitzer at gmail.com
Mon Feb 7 08:52:22 EST 2011
Do you have tables with spatial indexes and Meta data?
Which king oracle version are you using? If it's not the latest, upgrade
On Feb 8, 2011 12:11 AM, "Cristian Licari Puntodoc Srl" <
cristian.licari at puntodoc.net> wrote:
> Yes,
> MapGuide Server runs on a Windows Server 2003 32bit and the same is for
Oracle Db.
> I've created my DNS on the machine where runs MG and set up the tns ora.
> The DSN connects correctly to the specified SID.
> If I want to connect at DSN I need to specified the MapGuide Credentials
> I've specified in Studio User Id and password correctly (I hope)..
> After this I test the connection and it returns Connection Successful
> The problem occurs when I try to show the tables of db.
> The list of tables is empty and if I read the error log of mapguide, I
find the exception.
> I don't have an Oracle Spatial, I'm using Oracle 9.2.0.1
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110208/bf2e33f2/attachment.html
