[mapguide-users] Oracle Connection
Cristian Licari Puntodoc Srl
cristian.licari at puntodoc.net
Mon Feb 7 08:57:39 EST 2011
I'm not using Oracle Spatial... and I'm not using King Oracle FDO.
I'm using ODBC Driver to connect to DNS... _____
From: Zac Spitzer [mailto:zac.spitzer at gmail.com]
To: MapGuide Users Mail List [mailto:mapguide-users at lists.osgeo.org]
Sent: Mon, 07 Feb 2011 14:52:22 +0100
Subject: Re: [mapguide-users] Oracle Connection
Do you have tables with spatial indexes and Meta data?
Which king oracle version are you using? If it's not the latest, upgrade
On Feb 8, 2011 12:11 AM, "Cristian Licari Puntodoc Srl" <cristian.licari at puntodoc.net> wrote:
> Yes,
> MapGuide Server runs on a Windows Server 2003 32bit and the same is for Oracle Db.
> I've created my DNS on the machine where runs MG and set up the tns ora.
> The DSN connects correctly to the specified SID.
> If I want to connect at DSN I need to specified the MapGuide Credentials
> I've specified in Studio User Id and password correctly (I hope)..
> After this I test the connection and it returns Connection Successful
> The problem occurs when I try to show the tables of db.
> The list of tables is empty and if I read the error log of mapguide, I find the exception.
> I don't have an Oracle Spatial, I'm using Oracle 9.2.0.1
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110207/9be5a1ea/attachment.html
