[mapguide-users] SV: Can't select features using commercial
overlays
Zac Spitzer
zac.spitzer at gmail.com
Tue Feb 22 05:34:25 EST 2011
can you post yours?
On Tue, Feb 22, 2011 at 9:31 PM, Von Barth, Peter <Peter.vonBarth at eon.se> wrote:
> Can someone, who has a working google integrated application post a copy of their index.html file so I can compare with mine, to see if I'm missing something.
> -----Ursprungligt meddelande-----
> Från: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] För Zac Spitzer
> Skickat: den 16 februari 2011 14:21
> Till: MapGuide Users Mail List
> Ämne: Re: [mapguide-users] SV: Can't select features using commercial overlays
> Your using an older version of Fusion, I would recommend trying
> the latest version, which is 2.2
> But, the RC3 build has a problem with fusion, RC2 was missing tooltips
> and JPEG tiles were broken, the next and hopefully final build will have
> both fixed
> z
> On Thu, Feb 17, 2011 at 12:12 AM, Von Barth, Peter
>> I'm using 2.1 and studio 2009
>> Skickat: den 16 februari 2011 11:15
>> overlays
>> Which version are you using?
>> On Feb 16, 2011 8:11 PM, "Peter von Barth" <peter.vonbarth at eon.se> wrote:
>>> Yes, all available attributes are checked for selection for this layer. If
>>> I remove the google basemap everything works fine, and the attributes are
>>> displayed in the selection pane.
>>> Från: Jackie Ng [via OSGeo.org] [mailto:[hidden email]]
>>> Skickat: den 15 februari 2011 01:13
>>> Till: Von Barth, Peter
>>> Ämne: Re: Can't select features using commercial overlays
>>> Have you checked that the layer definition in question has any feature
>>> attributes checked when selected?
>>> - Jackie
>>> ________________________________
>>> If you reply to this email, your message will be added to the discussion
>>> below:
>>> http://osgeo-org.1803224.n2.nabble.com/Can-t-select-features-using-commercial-overlays-tp6023133p6025795.html
>>> To unsubscribe from Can't select features using commercial overlays, click
>>> here.
>>> View this message in context: SV: Can't select features using commercial
>>> overlays
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> http://www.ennoble.com.au
> http://zacster.blogspot.com
> +61 405 847 168
Zac Spitzer
+61 405 847 168
