[mapguide-users] SV: SV: Can't select features using commercial overlays
Peter von Barth peter.vonbarth at eon.se
Tue Feb 22 05:39:58 EST 2011
Here it is along with my appdef
Från: zspitzer [via OSGeo.org] [mailto:ml-node+6051849-798589656-314974 at n2.nabble.com]
Skickat: den 22 februari 2011 11:35
Till: Von Barth, Peter
Ämne: Re: SV: Can't select features using commercial overlays
can you post yours?
On Tue, Feb 22, 2011 at 9:31 PM, Von Barth, Peter <[hidden email]</user/SendEmail.jtp?type=node&node=6051849&i=0>> wrote:
> Can someone, who has a working google integrated application post a copy of their index.html file so I can compare with mine, to see if I'm missing something.
> -----Ursprungligt meddelande-----
> Från: [hidden email]</user/SendEmail.jtp?type=node&node=6051849&i=1> [mailto:[hidden email]</user/SendEmail.jtp?type=node&node=6051849&i=2>] För Zac Spitzer
> Skickat: den 16 februari 2011 14:21
> Till: MapGuide Users Mail List
> Ämne: Re: [mapguide-users] SV: Can't select features using commercial overlays
> Your using an older version of Fusion, I would recommend trying
> the latest version, which is 2.2
> But, the RC3 build has a problem with fusion, RC2 was missing tooltips
> and JPEG tiles were broken, the next and hopefully final build will have
> both fixed
> z
> On Thu, Feb 17, 2011 at 12:12 AM, Von Barth, Peter
> <[hidden email]</user/SendEmail.jtp?type=node&node=6051849&i=3>> wrote:
>> I'm using 2.1 and studio 2009
>> Från: [hidden email]</user/SendEmail.jtp?type=node&node=6051849&i=4>
>> [mailto:[hidden email]</user/SendEmail.jtp?type=node&node=6051849&i=5>] För Zac Spitzer
>> Skickat: den 16 februari 2011 11:15
>> overlays
>> Which version are you using?
>> On Feb 16, 2011 8:11 PM, "Peter von Barth" <[hidden email]</user/SendEmail.jtp?type=node&node=6051849&i=6>> wrote:
>>> Yes, all available attributes are checked for selection for this layer. If
>>> I remove the google basemap everything works fine, and the attributes are
>>> displayed in the selection pane.
>>> Från: Jackie Ng [via OSGeo.org] [mailto:[hidden email]]
>>> Skickat: den 15 februari 2011 01:13
>>> Ämne: Re: Can't select features using commercial overlays
>>> Have you checked that the layer definition in question has any feature
>>> attributes checked when selected?
>>> - Jackie
>>> ________________________________
>>> If you reply to this email, your message will be added to the discussion
>>> below:
>>> http://osgeo-org.1803224.n2.nabble.com/Can-t-select-features-using-commercial-overlays-tp6023133p6025795.html<http://osgeo-org.1803224.n2.nabble.com/Can-t-select-features-using-commercial-overlays-tp6023133p6025795.html?by-user=t>
>>> To unsubscribe from Can't select features using commercial overlays, click
>>> here.
>>> View this message in context: SV: Can't select features using commercial
>>> overlays
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> mapguide-users mailing list
>>> [hidden email]</user/SendEmail.jtp?type=node&node=6051849&i=7>
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> [hidden email]</user/SendEmail.jtp?type=node&node=6051849&i=8>
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> http://www.ennoble.com.au
> http://zacster.blogspot.com
> +61 405 847 168
> [hidden email]</user/SendEmail.jtp?type=node&node=6051849&i=9>
> [hidden email]</user/SendEmail.jtp?type=node&node=6051849&i=10>
Zac Spitzer
+61 405 847 168
[hidden email]</user/SendEmail.jtp?type=node&node=6051849&i=11>
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1803224.n2.nabble.com/Can-t-select-features-using-commercial-overlays-tp6023133p6051849.html
To unsubscribe from Can't select features using commercial overlays, click here<http://osgeo-org.1803224.n2.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=6023133&code=cGV0ZXIudm9uYmFydGhAZW9uLnNlfDYwMjMxMzN8MTIyNTA1NjUy>.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Can-t-select-features-using-commercial-overlays-tp6023133p6051858.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110222/c3462835/attachment.html
