[mapguide-users] MGOS 2.2 RC2?
Trevor Wekel trevor_wekel at otxsystems.com
Fri Jan 7 11:15:42 EST 2011
Hi Zac,
Are you still having issues with raster after the reboot?  Does the MOSAIC(), CLIP(), RESAMPLE() error occur when viewing a map or creating a new map?
Regards,
Trevor
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: January 5, 2011 5:18 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] MGOS 2.2 RC2?
ok, rebooted, turns out my JAVA_HOME variable wasn't configured
On Thu, Jan 6, 2011 at 11:02 AM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> no i didn't, but i wasn't prompted to
> trying this out ( win 64 bit with 32 bit install)
> http://trac.osgeo.org/mapguide/wiki/MGOS22GdalProvider
> http://vbkto.dyndns.org/sdk/release-1500-gdal-1-6-mapserver-5-6.zip 404's
> so i tried this file
> http://vbkto.dyndns.org/sdk/Download.aspx?file=release-1500-gdal-1-6-mapserver-5-6.zip
> but I'm getting this error trying to view an image
> <2011-01-06T10:54:45>   2540    MapGuide Maestro v2.1.4.5245    127.0.0.1       Administrator
>  Error: An exception occurred in FDO component.
>        Only MOSAIC(), CLIP() and RESAMPLE() are supported.
> TrueMarble.250m.21600x21600.G3.tif .145 GB tiff
> running interactively I see
> C:\Program Files (x86)\OSGeo\MapGuide\Server\bin>set cpl_debug=on
> C:\Program Files (x86)\OSGeo\MapGuide\Server\bin>mgserver run
> Running the server interactively as an application instead of as a service.
> (6176) Server starting...
> (6176) Mentor Coordinate System Library
> (6176) Server started.
> GDAL: Auto register C:\Program Files (x86)\OSGeo\MapGuide\Server\bin\gdalplugins
> \gdal_ECW_JP2ECW.dll using GDALRegister_ECW_JP2ECW.
> \gdal_MrSID.dll using GDALRegister_MrSID.
> (4172) An exception occurred in FDO component.
> On Thu, Jan 6, 2011 at 10:54 AM, Trevor Wekel
> <trevor_wekel at otxsystems.com> wrote:
>> Hi Zac,
>> Did you do a reboot after the install (just checking...)?
>> Trevor
>> Sent: January 5, 2011 4:52 PM
>> I just tried the java install option and the java mapviewer didn't work
>> after install
>> I'm trying out Trevor's GDAL notes ( with tiled maps)
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> http://www.ennoble.com.au
> http://zacster.blogspot.com
> +61 405 847 168
Zac Spitzer
+61 405 847 168
