[mapguide-users] MGOS 2.2 RC2?
Zac Spitzer
zac.spitzer at gmail.com
Tue Jan 11 02:27:01 EST 2011
generally when viewing a map
<2011-01-11T18:14:09> 6936 MapGuide Maestro v2.1.4.5245 127.0.0.1 Administrator
Error: An exception occurred in FDO component.
Only MOSAIC(), CLIP() and RESAMPLE() are supported.
StackTrace:
- MgFeatureServiceHandler.ProcessOperation() line 83 file
c:\builds\mg22win32\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
- MgOpSelectFeaturesSpatial.Execute() line 110 file
c:\builds\mg22win32\mgdev\server\src\services\feature\OpSelectFeaturesSpatial.cpp
- MgServerFeatureService.SelectAggregate() line 541 file
c:\builds\mg22win32\mgdev\server\src\services\feature\ServerFeatureService.cpp
- MgServerSelectFeatures.SelectFeatures() line 266 file
c:\builds\mg22win32\mgdev\server\src\services\feature\ServerSelectFeatures.cpp
I did end up replacing the libpq.dll from your wiki notes with a 8.4.2
one, previously
I had problems even adding the images via maestro ( 1.4.2) it would get stuck
1/3rd of the way through 2.5 GB of raster (ecw for testing only haha), but
it works fine now.
I was trying to show Jackie the error, but this time it just worked
z
On Sat, Jan 8, 2011 at 3:15 AM, Trevor Wekel
<trevor_wekel at otxsystems.com> wrote:
> Hi Zac,
> Are you still having issues with raster after the reboot? Does the MOSAIC(), CLIP(), RESAMPLE() error occur when viewing a map or creating a new map?
> Regards,
> Trevor
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
> Sent: January 5, 2011 5:18 PM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] MGOS 2.2 RC2?
> ok, rebooted, turns out my JAVA_HOME variable wasn't configured
> On Thu, Jan 6, 2011 at 11:02 AM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
>> no i didn't, but i wasn't prompted to
>> trying this out ( win 64 bit with 32 bit install)
>> http://trac.osgeo.org/mapguide/wiki/MGOS22GdalProvider
>> http://vbkto.dyndns.org/sdk/release-1500-gdal-1-6-mapserver-5-6.zip 404's
>> so i tried this file
>> http://vbkto.dyndns.org/sdk/Download.aspx?file=release-1500-gdal-1-6-mapserver-5-6.zip
>> but I'm getting this error trying to view an image
>> <2011-01-06T10:54:45> 2540 MapGuide Maestro v2.1.4.5245 127.0.0.1 Administrator
>> TrueMarble.250m.21600x21600.G3.tif .145 GB tiff
>> running interactively I see
>> C:\Program Files (x86)\OSGeo\MapGuide\Server\bin>set cpl_debug=on
>> C:\Program Files (x86)\OSGeo\MapGuide\Server\bin>mgserver run
>> Running the server interactively as an application instead of as a service.
>> (6176) Server starting...
>> (6176) Mentor Coordinate System Library
>> (6176) Server started.
>> GDAL: Auto register C:\Program Files (x86)\OSGeo\MapGuide\Server\bin\gdalplugins
>> \gdal_ECW_JP2ECW.dll using GDALRegister_ECW_JP2ECW.
>> \gdal_MrSID.dll using GDALRegister_MrSID.
>> (4172) An exception occurred in FDO component.
>> On Thu, Jan 6, 2011 at 10:54 AM, Trevor Wekel
>>> Hi Zac,
>>> Did you do a reboot after the install (just checking...)?
>>> Trevor
>>> Sent: January 5, 2011 4:52 PM
>>> I just tried the java install option and the java mapviewer didn't work
>>> after install
>>> I'm trying out Trevor's GDAL notes ( with tiled maps)
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> Zac Spitzer
>> Solution Architect / Director
>> Ennoble Consultancy Australia
>> http://www.ennoble.com.au
>> http://zacster.blogspot.com
>> +61 405 847 168
> Zac Spitzer
> +61 405 847 168
Zac Spitzer
+61 405 847 168
