[mapguide-users] MGOS 2.2 RC2?
Zac Spitzer
zac.spitzer at gmail.com
Tue Jan 11 02:43:21 EST 2011
actually GDAL got it to work (this time with true marble) both tiled
and untiled
http://www.unearthedoutdoors.net/global_data/true_marble/download
after manually overriding the coordinate system to wgs84 ll
the file seems ok, but maestro read it as
LOCAL_CS["*XY-MT*",LOCAL_DATUM["*X-Y*",10000],UNIT["Meter",
1],AXIS["X",EAST],AXIS["Y",NORTH]]
C:\bin\gdalwin\gdalwin32-1.5\bin>gdalinfo.exe c:\data\TrueMarble.250m.21600x2160
0.G3.tif
Driver: GTiff/GeoTIFF
Files: c:\data\TrueMarble.250m.21600x21600.G3.tif
Size is 21600, 21600
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.2572235630016,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]]
Origin = (90.000000000000000,0.000000000000000)
Pixel Size = (0.002083333333333,-0.002083333333333)
Metadata:
AREA_OR_POINT=Area
Image Structure Metadata:
INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left ( 90.0000000, 0.0000000)
Lower Left ( 90.0000000, -45.0000000)
Upper Right ( 135.0000000, 0.0000000)
Lower Right ( 135.0000000, -45.0000000)
Center ( 112.5000000, -22.5000000)
Band 1 Block=512x512 Type=Byte, ColorInterp=Red
Band 2 Block=512x512 Type=Byte, ColorInterp=Green
Band 3 Block=512x512 Type=Byte, ColorInterp=Blue
On Tue, Jan 11, 2011 at 6:27 PM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> generally when viewing a map
> <2011-01-11T18:14:09> 6936 MapGuide Maestro v2.1.4.5245 127.0.0.1 Administrator
> Error: An exception occurred in FDO component.
> Only MOSAIC(), CLIP() and RESAMPLE() are supported.
> StackTrace:
> - MgFeatureServiceHandler.ProcessOperation() line 83 file
> c:\builds\mg22win32\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
> - MgOpSelectFeaturesSpatial.Execute() line 110 file
> c:\builds\mg22win32\mgdev\server\src\services\feature\OpSelectFeaturesSpatial.cpp
> - MgServerFeatureService.SelectAggregate() line 541 file
> c:\builds\mg22win32\mgdev\server\src\services\feature\ServerFeatureService.cpp
> - MgServerSelectFeatures.SelectFeatures() line 266 file
> c:\builds\mg22win32\mgdev\server\src\services\feature\ServerSelectFeatures.cpp
> I did end up replacing the libpq.dll from your wiki notes with a 8.4.2
> one, previously
> I had problems even adding the images via maestro ( 1.4.2) it would get stuck
> 1/3rd of the way through 2.5 GB of raster (ecw for testing only haha), but
> it works fine now.
> I was trying to show Jackie the error, but this time it just worked
> z
> On Sat, Jan 8, 2011 at 3:15 AM, Trevor Wekel
> <trevor_wekel at otxsystems.com> wrote:
>> Hi Zac,
>> Are you still having issues with raster after the reboot? Does the MOSAIC(), CLIP(), RESAMPLE() error occur when viewing a map or creating a new map?
>> Regards,
>> Trevor
>> -----Original Message-----
>> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
>> Sent: January 5, 2011 5:18 PM
>> To: MapGuide Users Mail List
>> Subject: Re: [mapguide-users] MGOS 2.2 RC2?
>> ok, rebooted, turns out my JAVA_HOME variable wasn't configured
>> On Thu, Jan 6, 2011 at 11:02 AM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
>>> no i didn't, but i wasn't prompted to
>>> trying this out ( win 64 bit with 32 bit install)
>>> http://trac.osgeo.org/mapguide/wiki/MGOS22GdalProvider
>>> http://vbkto.dyndns.org/sdk/release-1500-gdal-1-6-mapserver-5-6.zip 404's
>>> so i tried this file
>>> http://vbkto.dyndns.org/sdk/Download.aspx?file=release-1500-gdal-1-6-mapserver-5-6.zip
>>> but I'm getting this error trying to view an image
>>> <2011-01-06T10:54:45> 2540 MapGuide Maestro v2.1.4.5245 127.0.0.1 Administrator
>>> TrueMarble.250m.21600x21600.G3.tif .145 GB tiff
>>> running interactively I see
>>> C:\Program Files (x86)\OSGeo\MapGuide\Server\bin>set cpl_debug=on
>>> C:\Program Files (x86)\OSGeo\MapGuide\Server\bin>mgserver run
>>> Running the server interactively as an application instead of as a service.
>>> (6176) Server starting...
>>> (6176) Mentor Coordinate System Library
>>> (6176) Server started.
>>> GDAL: Auto register C:\Program Files (x86)\OSGeo\MapGuide\Server\bin\gdalplugins
>>> \gdal_ECW_JP2ECW.dll using GDALRegister_ECW_JP2ECW.
>>> \gdal_MrSID.dll using GDALRegister_MrSID.
>>> (4172) An exception occurred in FDO component.
>>> On Thu, Jan 6, 2011 at 10:54 AM, Trevor Wekel
>>>> Hi Zac,
>>>> Did you do a reboot after the install (just checking...)?
>>>> Trevor
>>>> Sent: January 5, 2011 4:52 PM
>>>> I just tried the java install option and the java mapviewer didn't work
>>>> after install
>>>> I'm trying out Trevor's GDAL notes ( with tiled maps)
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> Zac Spitzer
>>> Solution Architect / Director
>>> Ennoble Consultancy Australia
>>> http://www.ennoble.com.au
>>> http://zacster.blogspot.com
>>> +61 405 847 168
>> Zac Spitzer
>> +61 405 847 168
> Zac Spitzer
> +61 405 847 168
Zac Spitzer
+61 405 847 168
