[mapguide-users] Re: installation script
Trevor Wekel
trevor_wekel at otxsystems.com
Fri Jan 7 11:24:17 EST 2011
Hi Anil,
The "building" guide for CentOS 5.4 http://trac.osgeo.org/mapguide/wiki/CompilingMapGuide22Centos54 lists all of the CentOS packages required to build and run MapGuide. You will probably need the "lib" versions of lines two and three:
yum install libjpeg libpng fontconfig freetype
yum install libxml2 expat curl libxslt openldap
There is also an RC1 binary build for CentOS 5.4(+) posted on OSGeo http://download.osgeo.org/mapguide/releases/2.2.0/RC1/mapguideopensource-2.2.0.5197-centos5.tar.gz
Regards,
Trevor
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Anil Thapa
Sent: January 6, 2011 11:47 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Re: installation script
hi,
i also get this error when starting apache
httpd: Syntax error on line 106 of
/usr/local/mapguideopensource-2.2.0/webserverextensions/apache2/conf/httpd.conf:
Cannot load
/usr/local/mapguideopensource-2.2.0/webserverextensions/apache2/modules/libphp5.so
into server: libexslt.so.0: cannot open shared object file: No such file
or directory
A
> Hi, I had no trouble on 5.4 but haven't tried 5.5
> Download the MapGuide 2.2 Beta from
> http://trac.osgeo.org/mapguide/wiki/Release/2.2Beta/Notes
> Unzip the 2 tar balls
> Run the ./mgserverd.sh and ./apachectl start to get MapGuide and Apache
> running.
> http://osgeo-org.1803224.n2.nabble.com/installation-script-tp5896189p5896209.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
