[mapguide-users] Re: installation script
Anil Thapa
anilth at hi.is
Fri Jan 7 11:44:24 EST 2011
Hello Trevor,
Thanks !!! I downloaded the beta version and started mgserverd.sh and
apachectl, now i can see the admin page. however when i try to login to
admin interface with Administrator ID: Administartor and password :
admin it returns with "cannot establish connection".
Any hint on this would be helpful
Anil
On 01/07/2011 04:24 PM, Trevor Wekel wrote:
> Hi Anil,
> The "building" guide for CentOS 5.4 http://trac.osgeo.org/mapguide/wiki/CompilingMapGuide22Centos54 lists all of the CentOS packages required to build and run MapGuide. You will probably need the "lib" versions of lines two and three:
> yum install libjpeg libpng fontconfig freetype
> yum install libxml2 expat curl libxslt openldap
> There is also an RC1 binary build for CentOS 5.4(+) posted on OSGeo http://download.osgeo.org/mapguide/releases/2.2.0/RC1/mapguideopensource-2.2.0.5197-centos5.tar.gz
> Regards,
> Trevor
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Anil Thapa
> Sent: January 6, 2011 11:47 AM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] Re: installation script
> hi,
> i also get this error when starting apache
> httpd: Syntax error on line 106 of
> /usr/local/mapguideopensource-2.2.0/webserverextensions/apache2/conf/httpd.conf:
> Cannot load
> /usr/local/mapguideopensource-2.2.0/webserverextensions/apache2/modules/libphp5.so
> into server: libexslt.so.0: cannot open shared object file: No such file
> or directory
> A
>> Hi, I had no trouble on 5.4 but haven't tried 5.5
>> Download the MapGuide 2.2 Beta from
>> http://trac.osgeo.org/mapguide/wiki/Release/2.2Beta/Notes
>> Unzip the 2 tar balls
>> Run the ./mgserverd.sh and ./apachectl start to get MapGuide and Apache
>> running.
>> View this message in context:
>> http://osgeo-org.1803224.n2.nabble.com/installation-script-tp5896189p5896209.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110107/54c66a78/attachment.html
