[mapguide-users] Re: installation script
Trevor Wekel trevor_wekel at otxsystems.com
Fri Jan 7 11:47:43 EST 2011
The MapGuide Server daemon may not be starting.  Try running mgserver.sh from the command line (no "d").  It may provide more information on any missing shared libs.  The daemon will fail silently if it is missing so's.
Trevor
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Anil Thapa
Sent: January 7, 2011 9:44 AM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Re: installation script
Hello Trevor,
Thanks !!! I downloaded the beta version and started mgserverd.sh and apachectl, now i can see the admin page. however when i try to login to admin interface with Administrator ID: Administartor and password : admin it returns with "cannot establish connection".
Any hint on this would be helpful
Anil
On 01/07/2011 04:24 PM, Trevor Wekel wrote:
Hi Anil,
The "building" guide for CentOS 5.4 http://trac.osgeo.org/mapguide/wiki/CompilingMapGuide22Centos54 lists all of the CentOS packages required to build and run MapGuide.  You will probably need the "lib" versions of lines two and three:
yum install libjpeg libpng fontconfig freetype
yum install libxml2 expat curl libxslt openldap
There is also an RC1 binary build for CentOS 5.4(+) posted on OSGeo http://download.osgeo.org/mapguide/releases/2.2.0/RC1/mapguideopensource-2.2.0.5197-centos5.tar.gz
Regards,
Trevor
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org<mailto:mapguide-users-bounces at lists.osgeo.org> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Anil Thapa
Sent: January 6, 2011 11:47 AM
To: MapGuide Users Mail List
hi,
i also get this error when starting apache
httpd: Syntax error on line 106 of
/usr/local/mapguideopensource-2.2.0/webserverextensions/apache2/conf/httpd.conf:
Cannot load
/usr/local/mapguideopensource-2.2.0/webserverextensions/apache2/modules/libphp5.so
into server: libexslt.so.0: cannot open shared object file: No such file
or directory
A
Hi, I had no trouble on 5.4 but haven't tried 5.5
Download the MapGuide 2.2 Beta from
http://trac.osgeo.org/mapguide/wiki/Release/2.2Beta/Notes
Unzip the 2 tar balls
Run the ./mgserverd.sh and ./apachectl start  to get MapGuide and Apache
running.
View this message in context:
http://osgeo-org.1803224.n2.nabble.com/installation-script-tp5896189p5896209.html
mapguide-users mailing list
mapguide-users at lists.osgeo.org<mailto:mapguide-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110107/f5d7ae7a/attachment.html
