[mapguide-users] Re: installation script
Anil Thapa anilth at hi.is
Fri Jan 7 12:06:45 EST 2011
Dear trevor,
I do not know what happened but i wrote start.sh script and put those
mgserver and apache start script and ran. it looks it is working now. I
really do not know what was the problem.
A
On 01/07/2011 04:47 PM, Trevor Wekel wrote:
> The MapGuide Server daemon may not be starting.  Try running
> mgserver.sh from the command line (no "d").  It may provide more
> information on any missing shared libs.  The daemon will fail silently
> if it is missing so's.
> Trevor
> *From:*mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Anil Thapa
> *Sent:* January 7, 2011 9:44 AM
> *To:* mapguide-users at lists.osgeo.org
> *Subject:* Re: [mapguide-users] Re: installation script
> Hello Trevor,
> Thanks !!! I downloaded the beta version and started mgserverd.sh and
> apachectl, now i can see the admin page. however when i try to login
> to admin interface with Administrator ID: Administartor and password :
> admin it returns with "cannot establish connection".
> Any hint on this would be helpful
> Anil
> On 01/07/2011 04:24 PM, Trevor Wekel wrote:
> Hi Anil,
> The "building" guide for CentOS 5.4http://trac.osgeo.org/mapguide/wiki/CompilingMapGuide22Centos54  lists all of the CentOS packages required to build and run MapGuide.  You will probably need the "lib" versions of lines two and three:
> yum install libjpeg libpng fontconfig freetype
> yum install libxml2 expat curl libxslt openldap
> There is also an RC1 binary build for CentOS 5.4(+) posted on OSGeohttp://download.osgeo.org/mapguide/releases/2.2.0/RC1/mapguideopensource-2.2.0.5197-centos5.tar.gz
> Regards,
> Trevor
> -----Original Message-----
> From:mapguide-users-bounces at lists.osgeo.org  <mailto:mapguide-users-bounces at lists.osgeo.org>  [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Anil Thapa
> Sent: January 6, 2011 11:47 AM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] Re: installation script
> hi,
> i also get this error when starting apache
> httpd: Syntax error on line 106 of
> /usr/local/mapguideopensource-2.2.0/webserverextensions/apache2/conf/httpd.conf:
> Cannot load
> /usr/local/mapguideopensource-2.2.0/webserverextensions/apache2/modules/libphp5.so
> into server: libexslt.so.0: cannot open shared object file: No such file
> or directory
> A
>     Hi, I had no trouble on 5.4 but haven't tried 5.5
>     Download the MapGuide 2.2 Beta from
>     http://trac.osgeo.org/mapguide/wiki/Release/2.2Beta/Notes
>     Unzip the 2 tar balls
>     Run the ./mgserverd.sh and ./apachectl start  to get MapGuide and Apache
>     running.
>     View this message in context:
>     http://osgeo-org.1803224.n2.nabble.com/installation-script-tp5896189p5896209.html
>     Sent from the MapGuide Users mailing list archive at Nabble.com.
>     _______________________________________________
>     mapguide-users mailing list
>     mapguide-users at lists.osgeo.org  <mailto:mapguide-users at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110107/4a2a0b0f/attachment.html
