[mapguide-users] selectionXML Problem
Zac Spitzer
zac.spitzer at gmail.com
Thu Jan 13 20:15:33 EST 2011
what datasources are you using?
what are the data types of your primary keys?
I've seen issues with 2.2 RC2 and doubles
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc43
z
On Fri, Jan 14, 2011 at 11:08 AM, Greg <gbneff at cid.utah.gov> wrote:
> I am having trouble getting the current selection by using GetSelectionXML(),
> passing the selection XML to the server and getting the selection. When a
> new item is selected for about 90% of the features, I get the correct Item.
> For the other 10%, the item is not found, even though the correct properties
> are shown in the properties pane. I am using the basic layout. Below is my
> code that takes the XML and gets the item from the Mapguide server. Any
> ideas what might be happening?
> String sessionId = Request.Form.Get("SID");
> String selectionXML = Server.UrlDecode(Request.Form.Get("sel"));
> //Response.Write("sessionId: " + sessionId + "<br>selectionXML: " +
> selectionXML);
> string realPath = Request.ServerVariables["APPL_PHYSICAL_PATH"];
> String configPath = realPath + "webconfig.ini";
> MapGuideApi.MgInitializeWebTier(configPath);
> MgUserInformation userInfo = new MgUserInformation(sessionId);
> MgSiteConnection siteConnection = new MgSiteConnection();
> siteConnection.Open(userInfo);
> if (siteConnection == null)
> Response.Write("Failed to get site connection.");
> return;
> MgResourceService resService =
> (MgResourceService)siteConnection.CreateService(MgServiceType.ResourceService);
> MgFeatureService featureService =
> (MgFeatureService)siteConnection.CreateService(MgServiceType.FeatureService);
> MgMap map = new MgMap();
> map.Open(resService, "Cid_Map");
> //get LineID information for selected feature (line)
> MgSelection selection = new MgSelection(map, selectionXML);
> MgLayer layer = (MgLayer)map.GetLayers().GetItem("lines_ss_cid");
> string strLayerClassName = layer.GetFeatureClassName();
> string strSelection = selection.GenerateFilter(layer,
> strLayerClassName);
> MgFeatureQueryOptions nameQuery = new MgFeatureQueryOptions();
> nameQuery.SetFilter(strSelection);
> MgResourceIdentifier resID = new
> MgResourceIdentifier("Library://data/sdf/lines_ss_cid.FeatureSource");
> MgFeatureReader featureReader = featureService.SelectFeatures(resID,
> "lines_ss_cid", nameQuery);
> string strLineID = "";
> if(featureReader.ReadNext())
> strLineID = featureReader.GetInt32("LineID").ToString();
> else
> //this shouldn't happen
> Response.Write("LineID not found in Mapguide datasource.");
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/selectionXML-Problem-tp5920249p5920249.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
