[mapguide-users] Re: selectionXML Problem
Greg
gbneff at cid.utah.gov
Thu Jan 13 21:38:25 EST 2011
Thanks for the reply.
The datasource is sdf. The primary key is int32. There are two columns in
the table of type double. The sdf file was created in Autocad Map. I have
re-created the table with no change. I am going to try creating it a
slightly different way to see if it makes a difference. The data looks
fine when I view it in Mapguide Studio. My map was created using Studio,
don't know if that makes a difference.
I have been wondering if something weird is happenning to the XML as I pass
it to the server.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/selectionXML-Problem-tp5920249p5920511.html
