[mapguide-users] Java Servlet Service Error
ar_gaeta ar_gaeta at yahoo.it
Wed Jan 19 04:18:11 EST 2011
Hi all, I don't know if this is the right section to post, but I have a
problem with my Apache/Tomcat.
I use MGE2011 on Vista, and until yesterday all my scripts (saved in file
".jsp" and containing code written in Java, html and javascript language)
were working PERFECTLY.
But just a second after, without ANY (apparently...) modification to some
scripts or something else, my scripts don't work anymore and I receive the
message attached at the end of this post.
I think that the problem is that Catalina (or Tomcat...I'm a newbie in this)
it's not able to write correctly some ".java" file.
Someone of you have encountered yet this problem? How I can solve it??
Thanks for any help
18-Jan-2011 19:08:24 org.apache.catalina.core.StandardWrapperValve invoke
SEVERE: Servlet.service() for servlet jsp threw exception
org.apache.jasper.JasperException: Unable to compile class for JSP:
An error occurred at line: 490 in the generated java file
Syntax error, insert "}" to complete Block
An error occurred at line: 500 in the generated java file
Syntax error on token "}", delete this token
An error occurred at line: 501 in the generated java file
Syntax error, insert "}" to complete ClassBody
Stacktrace:
	at
org.apache.jasper.compiler.DefaultErrorHandler.javacError(DefaultErrorHandler.java:92)
	at
org.apache.jasper.compiler.ErrorDispatcher.javacError(ErrorDispatcher.java:330)
	at
org.apache.jasper.compiler.JDTCompiler.generateClass(JDTCompiler.java:439)
	at org.apache.jasper.compiler.Compiler.compile(Compiler.java:334)
	at org.apache.jasper.compiler.Compiler.compile(Compiler.java:312)
	at org.apache.jasper.compiler.Compiler.compile(Compiler.java:299)
	at
org.apache.jasper.JspCompilationContext.compile(JspCompilationContext.java:589)
	at
org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:317)
	at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:313)
	at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:260)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:802)
	at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
	at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
	at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
	at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
	at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
	at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
	at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
	at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298)
	at org.apache.coyote.ajp.AjpAprProcessor.process(AjpAprProcessor.java:427)
	at
org.apache.coyote.ajp.AjpAprProtocol$AjpConnectionHandler.process(AjpAprProtocol.java:384)
	at org.apache.tomcat.util.net.AprEndpoint$Worker.run(AprEndpoint.java:1555)
	at java.lang.Thread.run(Thread.java:619)
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Java-Servlet-Service-Error-tp5938820p5938820.html
