[mapguide-users] Re: Help regarding to set filter for a
layer programmatically using Java
Jackie Ng
jumpinjackie at gmail.com
Thu Jan 27 10:07:18 EST 2011
Unfortunately, MaestroAPI is a .net library and is only available for .net.
If you use PHP or Java, you are out of luck.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Help-regarding-to-set-filter-for-a-layer-programmatically-using-Java-tp3343625p5966610.html
