[mapguide-users] Re: Help regarding to set filter for a
layer programmatically using Java
Jackie Ng
jumpinjackie at gmail.com
Thu Jan 27 18:30:00 EST 2011
You have to understand that each language has its own unique set of libraries
and APIs for dealing with and processing XML data.
What is shown in the PHP examples for dealing with XML data does not
translate 1:1 directly to .net or java. You need to find an equivalent
library in java for working with such XML content.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Help-regarding-to-set-filter-for-a-layer-programmatically-using-Java-tp3343625p5968219.html
