[mapguide-users] Re: MGE performance. It's soooooo
Slllllllooooooowwww
Greg
gbneff at cid.utah.gov
Fri Jan 28 14:37:40 EST 2011
I have been working on a migration very similar to yours and also found the
Fusion viewer to be too slow by comparison to my Mapguide 6.5 aaplication.
We have used an application built on Mapguide 6.5 and Coldfusion for many
years with great success. I have started the migration process 2 times
before and quit because of performance issues. This time I have finally got
a Mapguide Open Source app working that has performance equal or better to
my 6.5 app. If you are interested, here is what I have done:
MGOS 2.2
IIS VER 7.5
SQL SERVER 2008
Basic Viewer Layout (AJAX)
- map data is all sdf stored on the server
- raster data is tiff using GDAL provider and optimized for display at
different resolutions
- secondary data is retrieved from sql data source as features are selected
and displayed in basic viewer task pane or new window
- not using tooltips to help with performance
- map has 13 layers mostly parcels and utilities -one of the layers is
themed
- using .net and C# for development
It's not very fancy, but it works well and the performance great.
Here is a picture of my initial map view which takes about 2 seconds to
load:
http://osgeo-org.1803224.n2.nabble.com/file/n5970986/map.png
frosty1_4me wrote:
> Hi,
> We have been working on a complete migration from 6.5 to MGE as a pilot to
> see if we can actually move to the new platform since the 6.5 software is
> no longer supported.
> We have brought across everything from our 6.5 app to the new MGE
> framework (using fusion due to the required functionality), we have also
> made alot of changes in an attempt to speed up our data. We currently use
> SQL for our db's, but we've went so far as to setup static tables instead
> of news in the db, we have also imported data and stored in directly in
> the SDF's to try and speed things up, but nothing we have tried really
> makes a difference. The performance of MGE using Fusion is unbelievabley
> slow and there doesn't seem to be anything we can do.
> Take for example a simple SDF3 of parcels. We created an SDF3 that has
> about 23k parcels and instead of linking it to a db, we attached the data
> to the parcels in an attempt to speed up the flyouts in MGE. The data is
> only a simple ID, and another db field for testing purposes. We used the
> tooltip method in MGE and we also tried using an aspx page to load the
> simple dataset instead of the tooltip directly accessing the data from the
> attribute list in MGE. The results were the same, slow flyout loading
> times. To make things worse, if we turned on a layer which has alot of
> data, then tested the flyouts again for the parcels, it takes about 15secs
> for the flyout to appear. Obviously thats not acceptable.
> I don't know what else we can do with all of this. The performance of MGE
> is absolutely horrible, and after using 6.5 for so long we actually are
> considering going to a completely different GIS software. (Esri?)
> How are others dealign with this performance issue? The basic AJAX viewer
> is faster, but you also don't have the tools and flexablitly that you do
> with the Fusion setup.
> Thanks.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/MGE-performance-It-s-soooooo-Slllllllooooooowwww-tp5970714p5970986.html
