[mapguide-users] Re: how can i use <CompoundSymbolDefinition>……
Steve G
steve.golden at morganhill.ca.gov
Mon Jul 11 12:05:28 EDT 2011
Here is one way to show arrows:
http://trac.osgeo.org/mapguide/wiki/AdvancedStylization/Library/Generic
Another way would be to use the ">" symbol as repeating text content like
this:
(> is the same as > in terms of html special entities):
<?xml version="1.0" encoding="utf-8"?>
<SimpleSymbolDefinition
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema" version="1.1.0"
xsi:noNamespaceSchemaLocation="SymbolDefinition-1.0.0.xsd">
<Name>Sewer_GravityMain</Name>
<Graphics>
<Path>
<Geometry> M 0.0, 0.0 L 20.0,0.0</Geometry>
<LineColor>ff00ff00</LineColor>
<LineWeight>.2</LineWeight>
</Path>
<Text>
<Content>'>'</Content>
<FontName>'Arial'</FontName>
<Height>6</Height>
<PositionX>10</PositionX>
<PositionY>0</PositionY>
<TextColor>ff00ff00</TextColor>
</Text>
</Graphics>
<LineUsage>
<Repeat>20</Repeat>
</LineUsage>
<ParameterDefinition />
</SimpleSymbolDefinition>
If you don't understand the syntax, then you should look at the following:
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc14
http://trac.osgeo.org/mapguide/raw-attachment/wiki/AdvancedStylization/building_symbol_libraries.pdf
-Steve
View this message in context: http://osgeo-org.1803224.n2.nabble.com/how-can-i-use-CompoundSymbolDefinition-tp6569549p6571484.html
