[mapguide-users] Re: Maestro: Error in validating FlexibleLayout ymin < ymax
Nathan Elmore elmore.nathan at gmail.com
Tue Jul 12 11:37:20 EDT 2011
It is the 110m land shp file from natural earth data (
http://www.naturalearthdata.com/downloads/110m-physical-vectors/). It gives
the same result for the populated places maps too.
I loaded it using the SHP Load Procedure. Then I create a map definition,
which saves and validates with the message: "no primary key". Then I create
a "Application Definition". If I click "Preview", it loads fine with no
errors or warnings shown by firebug. When I click save or validate, I get
that error.
More info that might be helpful:
In the map definition, the initial map view is (-180,180,-90,90) and the
Coordinate system is:
GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_
1984",6378137.0,298.257223563]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.
0174532925199433]]
-Nate
On Mon, Jul 11, 2011 at 7:19 PM, Jackie Ng <jumpinjackie at gmail.com> wrote:
> What is the extent of your Map Definition?
> - Jackie
> http://osgeo-org.1803224.n2.nabble.com/Maestro-Error-in-validating-FlexibleLayout-ymin-ymax-tp6572023p6573404.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110712/aad597dc/attachment.html
