[mapguide-users] Re: Can't get fusion to work using Sheboygan and
Google Maps
Nathan Elmore
elmore.nathan at gmail.com
Thu Jul 14 12:24:49 EDT 2011
Oh I see - Thank you. The fusion
wiki<http://trac.osgeo.org/fusion/wiki/MapGuideCommercialOverlays>commercial
overlays guide uses a WKT example to project Sheboygan, but it
does not validate, so I tried selecting the Pseudo Mercator in the
projection. If it would be beneficial, I'll write up an updated tutorial
when I get this working.
Is it possible to project the WGS84 to Pseudo Mercator using the
MgCoordinateSystem Object and for use with Fusion (I know you can with the
AJAX viewers)? Correct me if I am wrong, but from what I can tell in the
docs, its only for the AJAX viewers because Fusion gets MapDefinitions from
the ApplicationDefinition.xml file.
How would you go about tackling this? Or would you use GDAL to transform
coordinate systems?
Thank you
On Wed, Jul 13, 2011 at 7:48 PM, Jackie Ng <jumpinjackie at gmail.com> wrote:
> The "The value cannot be less than or equal to zero" error is a nonsense
> error generally caused by the Map Definition not being visible in the
> current viewport.
> You said you converted your Map Definition to PseudoMercator. Did you also
> manually convert the extent coordinates? Maestro cannot transform extents
> to
> PseudoMercator coordinates, and thus manual conversion is required.
> - Jackie
> http://osgeo-org.1803224.n2.nabble.com/Can-t-get-fusion-to-work-using-Sheboygan-and-Google-Maps-tp6580834p6581584.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110714/4c72b8db/attachment.html
