[mapguide-users] Re: Can't get fusion to work using Sheboygan and Google Maps
Jackie Ng jumpinjackie at gmail.com
Thu Jul 14 21:57:15 EDT 2011
Yes of course you can use MgCoordinateSystem API to do this. A simple
PHP/Java/.net page using this API where you enter the source/target CS and
point(s) to be transformed in a form and it spits out a transformed result
when you submit is sufficient enough.
The problem is, MgCoordinateSystem is a web tier API that Maestro cannot tap
into on the client side. Maestro therefore uses its own coordinate system
library (Net Topology Suite), that is significantly less capable than
MgCoordinateSystem, but is more portable.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Can-t-get-fusion-to-work-using-Sheboygan-and-Google-Maps-tp6580834p6585662.html
