[mapguide-users] Re: Can't get fusion to work using Sheboygan and Google Maps
Nathan Elmore elmore.nathan at gmail.com
Fri Jul 15 13:53:01 EDT 2011
Awesome- Do I need to create a new MapDefinition (or new layers?) with the
new coordinate system? Or do I use MgCoordinateSystem API to do this after
Fusion has loaded the untransformed map definition?
-N
On Thu, Jul 14, 2011 at 7:57 PM, Jackie Ng <jumpinjackie at gmail.com> wrote:
> Yes of course you can use MgCoordinateSystem API to do this. A simple
> PHP/Java/.net page using this API where you enter the source/target CS and
> point(s) to be transformed in a form and it spits out a transformed result
> when you submit is sufficient enough.
> The problem is, MgCoordinateSystem is a web tier API that Maestro cannot
> tap
> into on the client side. Maestro therefore uses its own coordinate system
> library (Net Topology Suite), that is significantly less capable than
> MgCoordinateSystem, but is more portable.
> - Jackie
> http://osgeo-org.1803224.n2.nabble.com/Can-t-get-fusion-to-work-using-Sheboygan-and-Google-Maps-tp6580834p6585662.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110715/eb208245/attachment.html
