[mapguide-users] RE: Quick Plot tool
Jackie Ng jumpinjackie at gmail.com
Sat Jul 16 05:42:38 EDT 2011
If you use fusion.js as-is, it should load the widget code separately.
single-file fusion combines the fusion library with the widget code, if you
use this version you *have* to rebuild the single-file fusion.
I'd take some time to learn to build fusion via ant (It's not that hard).
There is a lot of javascript (several MBs of files) you are serving to
users.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Quick-Plot-tool-tp6581077p6589247.html
