[mapguide-users] RE: Quick Plot tool
frosty1_4me
kbowman at cityofgp.com
Mon Jul 18 10:43:09 EDT 2011
Alright, thanks for the info Jackie I'll review this more.
btw, I did get the quick plot widget code integrated, but there wasn't any improvement on the functionality that I am experiencing however that could be because I'm not using the newer version of the fusion.js in your library.
From: Jackie Ng [via OSGeo.org] [mailto:ml-node+6589247-1245232101-270548 at n2.nabble.com]
Sent: July-16-11 3:43 AM
To: Kent Bowman
Subject: RE: Quick Plot tool
If you use fusion.js as-is, it should load the widget code separately.
single-file fusion combines the fusion library with the widget code, if you use this version you *have* to rebuild the single-file fusion.
I'd take some time to learn to build fusion via ant (It's not that hard). There is a lot of javascript (several MBs of files) you are serving to users.
- Jackie
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1803224.n2.nabble.com/Quick-Plot-tool-tp6581077p6589247.html
To unsubscribe from Quick Plot tool, click here<http://osgeo-org.1803224.n2.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=6581077&code=a2Jvd21hbkBjaXR5b2ZncC5jb218NjU4MTA3N3wxMDI5OTk0MTc=>.
This message, and any attached documents, may include proprietary or protected information. If you are not the intended recipient, please notify me, delete this message, and do not further communicate the information contained herein without my express written consent.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Quick-Plot-tool-tp6581077p6595029.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110718/a38c636c/attachment.html
