[mapguide-users] RE: Quick Plot tool
frosty1_4me
kbowman at cityofgp.com
Fri Jul 15 11:58:53 EDT 2011
Hi Jackie,
I gave your code a try but it just won't generate a map. I tried both just using your code as is, and then just taking the parts of the code to update my version without using the multi maps functionality but I get the same result doing both. The map preview doesn't generate, it just shows a message:
"The application resources required to generate the plot exceed the settings defined by the administrator"
Any idea as to what's causing this?
Thanks
Kent
From: Jackie Ng [via OSGeo.org] [mailto:ml-node+6581565-987449267-270548 at n2.nabble.com]
Sent: July-13-11 7:42 PM
To: Kent Bowman
Subject: Re: Quick Plot tool
My github fork of fusion has addressed many defects related to the QuickPlot widget.
https://github.com/jumpinjackie/fusion-multimap
Maybe it will solve your issues too.
- Jackie
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1803224.n2.nabble.com/Quick-Plot-tool-tp6581077p6581565.html
To unsubscribe from Quick Plot tool, click here<http://osgeo-org.1803224.n2.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=6581077&code=a2Jvd21hbkBjaXR5b2ZncC5jb218NjU4MTA3N3wxMDI5OTk0MTc=>.
This message, and any attached documents, may include proprietary or protected information. If you are not the intended recipient, please notify me, delete this message, and do not further communicate the information contained herein without my express written consent.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Quick-Plot-tool-tp6581077p6587349.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110715/880bbf5e/attachment.html
