[mapguide-users] Re: Problem with raster
Jackie Ng
jumpinjackie at gmail.com
Mon Jul 18 08:46:43 EDT 2011
That's just a normal warning you get when the GDAL provider could not
determine the extents of the raster image, so the provider just returns an
arbitrarly large extent (+/- 1000000 ). It's a warning because the extent is
usually way too large and a layer that is created off of it usually cannot
be previewed.
I have made a patch for the GDAL provider recently that should drastically
improve the extent detection in this provider. It should return the same
numbers for any raster, as the ones returned by the gdalinfo.exe utility.
Patched versions of the GDAL provider are available here:
http://trac.osgeo.org/mapguide/wiki/MGOS22GdalProvider
It is strongly advised to install this patched provider in the above link.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Problem-with-raster-tp6594454p6594598.html
