[mapguide-users] re: dynamic layer generation
girish kumar bv
girish778 at rediffmail.com
Wed Jul 20 03:56:12 EDT 2011
hi, i am creating a xml marker layer to be overlayed on the existing map layer on search, initially before search map coordinates are x: 301620.238896, y: 2343288.901354 (degree) however the coordinates change to x: nan, y: nan (degree) and does not display the xml layer on existing map after search. can anyone suggest a solution for the above problem. however, even when i try to make an selection on the layer programmatically, then also i face the same problem projection of shapefiles used are : utm - wgs84 xml marker projection - string utmwkt="projcs[\"wgs_1984_utm_zone_43n\",geogcs[\"gcs_wgs_1984\",datum[\"d_wgs_1984\",spheroid[\"wgs_1984\",6378137.0,298.257223563]],primem[\"greenwich\",0.0],unit[\"degree\",0.0174532925199433]],projection[\"transverse_mercator\"],parameter[\"false_easting\",500000.0],parameter[\"false_northing\",0.0],parameter[\"central_meridian\",75.0],parameter[\"scale_factor\",0.9996],parameter[\"latitude_of_origin\",0.0],unit[\"meter\",1.0]]"; i am attaching the url from which the application can be accessed http://118.102.160.131/mapguide2011/nmc/ajaxtiledviewersample.jsp?domainname=nmc regards, girish
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110720/30de73ab/attachment.html
