[mapguide-users] Fusion custom widgets
Kevin Pelgrims Kevin.Pelgrims at realdolmen.com
Fri Jul 29 10:48:37 EDT 2011
Hi all,
Are there any good recources on developing custom widgets for the Fusion viewer? Preferably also mentioning the use of backend code (I'll need to use asp.net) with it.
I found some info on this, but it's all very basic, only found stuff about what a widget is and some explanation about the xml.
I usually understand things better with a good example, so I was hoping there'd be one for a more complicated custom widget.
Thanks!
Regards,
Kevin
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110729/91a8c915/attachment.html
