[mapguide-users] Re: Fusion Viewer Error
Jackie Ng jumpinjackie at gmail.com
Thu Jun 9 22:11:27 EDT 2011
Pre-defined units are stored in an array in the fusion library, it could be
that the unit in question doesn't resolve to a known item?
Here's a little test, can you reproduce the problem with the Sheboygan
dataset by setting the coordinate system of the Map Definition in a
feet-based coordinate system? If so, then it gives us something to work with
to find a resolution for this issue.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Fusion-Viewer-Error-tp6454124p6460656.html
