[mapguide-users] Re: Fusion Viewer Error
Michael Adair
madair at dmsolutions.ca
Fri Jun 10 09:24:26 EDT 2011
Jackie has that one correct I think. Your WKT is returning units of
"Foot_US" and neither Fusion no Proj4js has any knowledge of this unit
name. If you can get the units to come out as just "Feet" your problem
should go away.
IMO this is why I'm not a fan of "WKT" because it's not so "WK" after
all without a standard.
Mike
On 09/06/2011 10:11 PM, Jackie Ng wrote:
> Pre-defined units are stored in an array in the fusion library, it could be
> that the unit in question doesn't resolve to a known item?
> Here's a little test, can you reproduce the problem with the Sheboygan
> dataset by setting the coordinate system of the Map Definition in a
> feet-based coordinate system? If so, then it gives us something to work with
> to find a resolution for this issue.
> - Jackie
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Fusion-Viewer-Error-tp6454124p6460656.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
