[mapguide-users] Re: Fusion Viewer Error
Greg gbneff at cid.utah.gov
Fri Jun 10 11:01:42 EDT 2011
Jackie Ng wrote:
> Here's a little test, can you reproduce the problem with the Sheboygan
> dataset by setting the coordinate system of the Map Definition in a
> feet-based coordinate system?
> - Jackie
I tested with the Sheboygan sample data and got the same error.
Thanks for your help.  For now I will keep things in meters.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Fusion-Viewer-Error-tp6454124p6462576.html
