[mapguide-users] re: marker projection problem
girish kumar bv
girish778 at rediffmail.com
Wed Jun 15 08:14:13 EDT 2011
Hi all,
i am using mapguide 2.1 (java api) for development
I am creating a xml marker layer to be overlayed on the existing map
layer on search, initially before search map coordinates are X:
301620.238896, Y: 2343288.901354 (DEGREE) however the coordinates change
to X: NaN, Y: NaN (DEGREE) and does not display on existing map after
search. Can anyone suggest a solution for the above problem.
Layer Cordinate system
WGS_1984_UTM_Zone_43NPROJCS["WGS_1984_UTM_Zone_43N",GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137,298.257223563]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",75],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["Meter",1]]
Map Coordinate System
regards,
girish
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110615/9fd7e75f/attachment.html
