[mapguide-users] Coordinates are incorrect using fusion and google maps open layers
BradM brad.mason at dfo-mpo.gc.ca
Wed Jun 15 12:45:48 EDT 2011
Users want to see the correct lattitude and longitude coordinates in degrees
in geographic projection when using fusion with google map open layers.  If
users go to options in fusion 2.0 and select degrees,   the coordinates are
not correct.  Is this a bug with fusion or is there a fix?   thanks
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Coordinates-are-incorrect-using-fusion-and-google-maps-open-layers-tp6479646p6479646.html
