[mapguide-users] Coordinates are incorrect using fusion and
google maps open layers
Zac Spitzer
zac.spitzer at gmail.com
Thu Jun 16 03:38:18 EDT 2011
I'd suggest trying using the latest stable version of fusion 2.2,
there has been a lot of improvements since 2.0 and google
maps has also changed since 2 was released
http://trac.osgeo.org/fusion/
z
On Thu, Jun 16, 2011 at 2:45 AM, BradM <brad.mason at dfo-mpo.gc.ca> wrote:
> Users want to see the correct lattitude and longitude coordinates in degrees
> in geographic projection when using fusion with google map open layers. If
> users go to options in fusion 2.0 and select degrees, the coordinates are
> not correct. Is this a bug with fusion or is there a fix? thanks
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Coordinates-are-incorrect-using-fusion-and-google-maps-open-layers-tp6479646p6479646.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
