[mapguide-users] Re: Using MgResourceService.GetResourceData with SQL Spatial data
mszanto mszanto at microdesk.com
Fri Jun 17 09:39:25 EDT 2011
Jackie, thanks for your reply.
You make a valid point about fetching the *entire* data store.
As it turns out, my current implementation is the ideal solution because I
only copy the features the users wishes to download to the temporary feature
source and then execute GetResourceData against this temporary feature
source.
mike
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Using-MgResourceService-GetResourceData-with-SQL-Spatial-data-tp6471412p6487136.html
