[mapguide-users] Re: Map fails to load
gom gord.mckenzie at canam.com
Tue Jun 21 12:53:38 EDT 2011
What are the sizes and types of your datasets?  Do you use SDF, SHP, SQL etc.
How big are they, what types of data are in the datasets and how many layers
are in your maps.
Can you simplify any of your initial map layers and loading code?
I have had some odd errors when there was a bad ploygon in a polygon sdf
file for example.  I also had an issue on a virtual server with inadequete
resources where starting Mapguide would take 45 minutes because SQL Server
was taking forever to start up and the mapguide process would time out.
I'm not suggesting these are your particular issues but there are a lot of
things that could interact to cause issues.  Strip things down to the bare
minimum and build up from there if possible to see if you can identify what
the aggravating factor is.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Map-fails-to-load-tp6427544p6500837.html
