[mapguide-users] Re: Map Selection selects entire layer if more than 500 features are selected
elliott17 elliottd at ae.ca
Thu Jun 23 09:29:02 EDT 2011
This occurs when I perform a window selection with the mouse and when I query
features and have them selected via the query.  Whenever the selection is
greater than 500 records, all records are selected.  The number of selected
features in the status bar indicate the correct number. When I run a report
on these selected features, I get an error thrown
I am using MGOS 2.1 with SQL Server 2008 Express.  This is on an XP box with
IIS 5.
A shape file works correctly.  I run the data from SQL as I have views
created in SQL that run queries/math dynamically.
When I run a report on the SQL features, I get this error:
An exception occurred in FDO component.
RDBMS: [Microsoft][ODBC SQL Server Driver][SQL Server]Some part of your SQL
statement is nested too deeply. Rewrite the query or break it up into
smaller queries.
ERROR: Unable to retrieve data from the map.
No objects were selected from the TEST layer.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Map-Selection-selects-entire-layer-if-more-than-500-features-are-selected-tp6507020p6508277.html
