[mapguide-users] Re: Map Selection selects entire layer if more than 500 features are selected
Zac Spitzer zac.spitzer at gmail.com
Thu Jun 23 09:33:30 EDT 2011
nasty, can you test on 2.2? 2.1 is rather old... even 2.2's FDO 3.5 is old
On Thu, Jun 23, 2011 at 11:29 PM, elliott17 <elliottd at ae.ca> wrote:
> This occurs when I perform a window selection with the mouse and when I query
> features and have them selected via the query.  Whenever the selection is
> greater than 500 records, all records are selected.  The number of selected
> features in the status bar indicate the correct number. When I run a report
> on these selected features, I get an error thrown
> I am using MGOS 2.1 with SQL Server 2008 Express.  This is on an XP box with
> IIS 5.
> A shape file works correctly.  I run the data from SQL as I have views
> created in SQL that run queries/math dynamically.
> When I run a report on the SQL features, I get this error:
> An exception occurred in FDO component.
> RDBMS: [Microsoft][ODBC SQL Server Driver][SQL Server]Some part of your SQL
> statement is nested too deeply. Rewrite the query or break it up into
> smaller queries.
> ERROR: Unable to retrieve data from the map.
> No objects were selected from the TEST layer.
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Map-Selection-selects-entire-layer-if-more-than-500-features-are-selected-tp6507020p6508277.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
