[mapguide-users] Re: Map fails to load
Zac Spitzer
zac.spitzer at gmail.com
Tue Jun 28 22:46:40 EDT 2011
which viewer are you using? ajax or fusion (flexible)
Next time it hangs, can you try opening the map with firefox/firebug
and see which requests it failing on? Knowing how far it gets
before hanging will help identify the problem.
If you have a large spatial database in SQL, it may take a while to
describe the schema if you have a lot of tables.
Once solution for this is to create users which only have access
to a subset of the tables so that FDO will then only
You can also try enabling tracing which provides some very verbose
logging.
http://sandbox.mapguide.com/index.php/MapGuide_Trace_Logs
Regards
Zac
On Wed, Jun 29, 2011 at 3:41 AM, frosty1_4me <kbowman at cityofgp.com> wrote:
> Just a follow up to this. I haven't found a solution yet, but we were
> restarting the server each night and decided to change the frequency. Now,
> it doesn't restart and the map is loading fine for users. I think manual
> starts at the point is the work around.
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Map-fails-to-load-tp6427544p6525842.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
