[mapguide-users] Re: Map fails to load
GordonL
gordon.luckett at arrowgeomatics.com
Tue Jun 21 14:21:32 EDT 2011
JOINS to SQL Server might also be an issue, but I am not sure if that layer
is not inially visible if that would cause issues.
It would be great if FUSION would support tiled maps, then you can tile your
inital layers and speed things up.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Map-fails-to-load-tp6427544p6501157.html
