[mapguide-users] Re: Problem with coordinate system - buffer
brenda joseph brendajoseph82 at gmail.com
Thu Mar 24 03:11:28 EDT 2011
when i want to create buffer this error came out:-
  Create Buffer
 Buffer 1 has been created.
0 buffer feature was created.
*Warning:* 1 layer was excluded from buffer computation because its
coordinate system is incompatible with the coordinate system of the map, or
because it has no coordinate system at all
What type of coordinate system shoul i use acctually? coz i'm using lat
long, wgs 84.
Thanks and regards
On Thu, Mar 24, 2011 at 3:06 PM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> Can you explain the exact content of your problem?
> what kind of data, which viewer, which mapguide version etc
> On Thu, Mar 24, 2011 at 5:55 PM, bjoseph82 <brendajoseph82 at gmail.com>
> wrote:
> > how did u settle this problem. coz i'm facing the same proble right now
> > View this message in context:
> http://osgeo-org.1803224.n2.nabble.com/Problem-with-coordinate-system-buffer-tp1818573p6203045.html
> > Sent from the MapGuide Users mailing list archive at Nabble.com.
> > mapguide-users mailing list
> > mapguide-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> http://www.ennoble.com.au
> http://zacster.blogspot.com
> +61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110324/e195906b/attachment.html
