[mapguide-users] Re: Problem with coordinate system - buffer
Zac Spitzer
zac.spitzer at gmail.com
Thu Mar 24 03:34:57 EDT 2011
which mapguide version and viewer are you using ?
On Thu, Mar 24, 2011 at 6:11 PM, brenda joseph <brendajoseph82 at gmail.com>wrote:
> when i want to create buffer this error came out:-
> Create Buffer
> Buffer 1 has been created.
> 0 buffer feature was created.
> *Warning:* 1 layer was excluded from buffer computation because its
> coordinate system is incompatible with the coordinate system of the map, or
> because it has no coordinate system at all
> What type of coordinate system shoul i use acctually? coz i'm using lat
> long, wgs 84.
> Thanks and regards
> On Thu, Mar 24, 2011 at 3:06 PM, Zac Spitzer <zac.spitzer at gmail.com>wrote:
>> Can you explain the exact content of your problem?
>> what kind of data,
>> On Thu, Mar 24, 2011 at 5:55 PM, bjoseph82 <brendajoseph82 at gmail.com>
>> wrote:
>> > how did u settle this problem. coz i'm facing the same proble right now
>> > View this message in context:
>> http://osgeo-org.1803224.n2.nabble.com/Problem-with-coordinate-system-buffer-tp1818573p6203045.html
>> > Sent from the MapGuide Users mailing list archive at Nabble.com.
>> > _______________________________________________
>> > mapguide-users mailing list
>> > mapguide-users at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> Zac Spitzer
>> Solution Architect / Director
>> Ennoble Consultancy Australia
>> http://www.ennoble.com.au
>> http://zacster.blogspot.com
>> +61 405 847 168
Zac Spitzer
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110324/c8371cec/attachment.html
