[mapguide-users] Re: Problem with coordinate system - buffer
brenda joseph brendajoseph82 at gmail.com
Thu Mar 24 03:40:30 EDT 2011
i'm using MapGuideOpenSource-2.2.0.4829-Beta1, and ajax viewer.
Thanks
On Thu, Mar 24, 2011 at 3:34 PM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> which mapguide version and viewer are you using ?
>  On Thu, Mar 24, 2011 at 6:11 PM, brenda joseph <brendajoseph82 at gmail.com>wrote:
>>  when i want to create buffer this error came out:-
>>   Create Buffer
>>   Buffer 1 has been created.
>>  0 buffer feature was created.
>> *Warning:* 1 layer was excluded from buffer computation because its
>> coordinate system is incompatible with the coordinate system of the map, or
>> because it has no coordinate system at all
>> What type of coordinate system shoul i use acctually? coz i'm using lat
>> long, wgs 84.
>> Thanks and regards
>>   On Thu, Mar 24, 2011 at 3:06 PM, Zac Spitzer <zac.spitzer at gmail.com>wrote:
>>> Can you explain the exact content of your problem?
>>> what kind of data,
>>>  On Thu, Mar 24, 2011 at 5:55 PM, bjoseph82 <brendajoseph82 at gmail.com>
>>> wrote:
>>> > how did u settle this problem. coz i'm facing the same proble right now
>>> > View this message in context:
>>> http://osgeo-org.1803224.n2.nabble.com/Problem-with-coordinate-system-buffer-tp1818573p6203045.html
>>> > Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> > _______________________________________________
>>> > mapguide-users mailing list
>>> > mapguide-users at lists.osgeo.org
>>> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> Zac Spitzer
>>> Solution Architect / Director
>>> Ennoble Consultancy Australia
>>> http://www.ennoble.com.au
>>> http://zacster.blogspot.com
>>> +61 405 847 168
> Zac Spitzer
> +61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110324/f2abdce5/attachment.html
