[mapguide-users] Re: Problem with coordinate system - buffer
Zac Spitzer
zac.spitzer at gmail.com
Thu Mar 24 04:00:36 EDT 2011
have you checked what co-ordinate systems are being reported for
your map and feature sources?
On Thu, Mar 24, 2011 at 6:40 PM, brenda joseph <brendajoseph82 at gmail.com>wrote:
> i'm using MapGuideOpenSource-2.2.0.4829-Beta1, and ajax viewer.
> Thanks
> On Thu, Mar 24, 2011 at 3:34 PM, Zac Spitzer <zac.spitzer at gmail.com>wrote:
>> which mapguide version and viewer are you using ?
>> On Thu, Mar 24, 2011 at 6:11 PM, brenda joseph <brendajoseph82 at gmail.com
>> > wrote:
>>> when i want to create buffer this error came out:-
>>> Create Buffer
>>> Buffer 1 has been created.
>>> 0 buffer feature was created.
>>> *Warning:* 1 layer was excluded from buffer computation because its
>>> coordinate system is incompatible with the coordinate system of the map, or
>>> because it has no coordinate system at all
>>> What type of coordinate system shoul i use acctually? coz i'm using lat
>>> long, wgs 84.
>>> Thanks and regards
>>> On Thu, Mar 24, 2011 at 3:06 PM, Zac Spitzer <zac.spitzer at gmail.com>wrote:
>>>> Can you explain the exact content of your problem?
>>>> what kind of data,
>>>> On Thu, Mar 24, 2011 at 5:55 PM, bjoseph82 <brendajoseph82 at gmail.com>
>>>> wrote:
>>>> > how did u settle this problem. coz i'm facing the same proble right
>>>> now
>>>> > View this message in context:
>>>> http://osgeo-org.1803224.n2.nabble.com/Problem-with-coordinate-system-buffer-tp1818573p6203045.html
>>>> > Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>> > _______________________________________________
>>>> > mapguide-users mailing list
>>>> > mapguide-users at lists.osgeo.org
>>>> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>> Zac Spitzer
>>>> Solution Architect / Director
>>>> Ennoble Consultancy Australia
>>>> http://www.ennoble.com.au
>>>> http://zacster.blogspot.com
>>>> +61 405 847 168
>> Zac Spitzer
>> +61 405 847 168
Zac Spitzer
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110324/b104ecf3/attachment.html
