[mapguide-users] Re: Problem with coordinate system - buffer
brenda joseph brendajoseph82 at gmail.com
Thu Mar 24 04:08:27 EDT 2011
NO. HOW CAN I CHECK PLEASE
On Thu, Mar 24, 2011 at 4:00 PM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> have you checked what co-ordinate systems are being reported for
> your map and feature sources?
> On Thu, Mar 24, 2011 at 6:40 PM, brenda joseph <brendajoseph82 at gmail.com>wrote:
>> i'm using MapGuideOpenSource-2.2.0.4829-Beta1, and ajax viewer.
>> Thanks
>>   On Thu, Mar 24, 2011 at 3:34 PM, Zac Spitzer <zac.spitzer at gmail.com>wrote:
>>> which mapguide version and viewer are you using ?
>>>  On Thu, Mar 24, 2011 at 6:11 PM, brenda joseph <
>>> brendajoseph82 at gmail.com> wrote:
>>>>  when i want to create buffer this error came out:-
>>>>   Create Buffer
>>>>   Buffer 1 has been created.
>>>>  0 buffer feature was created.
>>>> *Warning:* 1 layer was excluded from buffer computation because its
>>>> coordinate system is incompatible with the coordinate system of the map, or
>>>> because it has no coordinate system at all
>>>> What type of coordinate system shoul i use acctually? coz i'm using lat
>>>> long, wgs 84.
>>>> Thanks and regards
>>>>   On Thu, Mar 24, 2011 at 3:06 PM, Zac Spitzer <zac.spitzer at gmail.com>wrote:
>>>>> Can you explain the exact content of your problem?
>>>>> what kind of data,
>>>>>  On Thu, Mar 24, 2011 at 5:55 PM, bjoseph82 <brendajoseph82 at gmail.com>
>>>>> wrote:
>>>>> > how did u settle this problem. coz i'm facing the same proble right
>>>>> now
>>>>> > View this message in context:
>>>>> http://osgeo-org.1803224.n2.nabble.com/Problem-with-coordinate-system-buffer-tp1818573p6203045.html
>>>>> > Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>>> > _______________________________________________
>>>>> > mapguide-users mailing list
>>>>> > mapguide-users at lists.osgeo.org
>>>>> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>>> Zac Spitzer
>>>>> Solution Architect / Director
>>>>> Ennoble Consultancy Australia
>>>>> http://www.ennoble.com.au
>>>>> http://zacster.blogspot.com
>>>>> +61 405 847 168
>>> Zac Spitzer
>>> +61 405 847 168
> Zac Spitzer
> +61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110324/f974c73e/attachment.html
